WOULD ANYONE HAVE A HOSE ROUTING -WATER & VACUUM- FOR THIS 53?
Submitted by bonnettoboot@e… on Tue, 10/19/2010 - 19:22
Submitted by SE98-32482CJ on Tue, 10/19/2010 - 18:45
120 fhc W/WASHERS
William it goes off the manifold (vac) to the push switch) to the vac side of the bottle. From the bottle it goes to a "T" in the cowl and off to each nozzel. The routing is through the inside of the car with the exception of the hose from the manifold to the cowl and the in and out lines from the bottle to the nozzels. Is that what you need?
Thank you for the quick response George it is working.
