I need pair of sealed beam fog lamps, 5 1/4 inch dia, for my 1966 Jaguar 3.4S. Any suggestion on sourcing will be greatly appreciated. Many thanks John Read
Submitted by jhread@optonline.net on Tue, 09/24/2013 - 15:06
Submitted by SE98-32482CJ on Tue, 09/24/2013 - 06:06
66 Jaguar 3.4S Fog Lights
John Spain sure helps---For that market the correct part would be the C.21731 (55286/A-WFT.6). John do you have a parts catalog for your car?
Submitted by jhread@optonline.net on Mon, 09/23/2013 - 19:50
Thanks very much George. I have located in the UK a pair of WFTS lights with correct mounting rims for my 3.4S. I will now focus on the "supporting members". My 3.4S was sold and delivered in Spain and eventually found its way to San Francisco where I purchased it, hence fog lights rather than the chrome grills.
Submitted by SE98-32482CJ on Mon, 09/23/2013 - 19:13
John then you need to source a Lucas lamp. The part number is a problem. For the USA there was a chrome grill. Then there are two long list of countries that either one or the other Lucas lamp was provided to. For simplicity you need either C.21731 (55285/A-WFT.6) or C21732 (55286/B-WFT.6). Switzerland only got a Cibie lamp (Cibie 12-86-43). Interesting that the other lamp is un named--I have only seen that in industrial/ aviation applications. Best of luck--try one or all of our fine supporting vendors!
Submitted by jhread@optonline.net on Mon, 09/23/2013 - 17:39
George, the diameter, edge to edge of glass is 5 1/4 to 5 5/16 inches. One bulb is Lucas and the other is unnamed and is burnt out. I would like to a matching pair.
Submitted by SE98-32482CJ on Mon, 09/23/2013 - 15:31
John do you have the Lucas or Cibie? There were two options but are you sure they were 5 1/4?
George, thanks for part number. Yes I have the part catalog, but it is with the Car in Florida and I am in New York. I will coordinate with my restoration guru. Welsh has advised they' can provide the fog lights and I have requested detail of the part number that they can provide.
