There is an outlet on a valve on the air cleaner housing that seems to call for a rubber hose (not the 2" corrugated heat tubing). If a rubber hose does connect to the valve on the air cleaner where does the other end of the hose connect?
Submitted by SE98-32482CJ on Mon, 01/16/2012 - 18:39
Dennis that hose goes to the thermal valve in the center of your air cleaner housing--when you find that you will notice there is a second pipe tat the vac source comes from. That is on the manifold.
