the door lock is stuck in the closed position. I CAN't see how to get the lock apart. the space is so small it is almost impossible to get a tool in the opening. How do i get the lock out? do i remove the chrome handle? then what? The door will open if u use the inside handle.
Submitted by SE98-32482CJ on Thu, 08/23/2012 - 13:07
Pat you must remove the entire assy. You can then open with the inside handle or you can push the opening paddle through the hole where your handle was.
