My antenna for the radio stopped going all the way down. Seems to do it when the weather gets colder.
I read in the manual that you can get some sort of liquid to claen the antenna with, anyone have any input on this? Do you have to get this at a dealership or can you pick up the same stuff at an autoparts store? I am guessing the later.
As always, I appreciate your input.
Dave Ashenfelter
1997 XJ6
Submitted by jam@ispwest.com on Fri, 10/28/2005 - 08:39
I keep mine lubricated with WD-40 by wiping it up, never down. If you wipe it down, you force dirt and grime into the section channels. A small amount of any penetrating oil or lubricant should do it. 3-in-1 oil is also good, even silicone spray.
