Several months ago I purchased the foam cushion that sits on top of the radiator in a 1970 Series II FHC. First I used spray adhesive with no luck; the foam came off. Then I tried several drops of silicone across the length of the foam; same result -- the foam came off.
Any suggestions on how to attach the foam so it will stay put?
Submitted by SE98-32482CJ on Mon, 08/05/2013 - 19:33
3M Super Glue always works
