When I appy pressure to brake pedal the dash light, for running lights, lights up. Any idea what this means?
Submitted by NE18-55081 on Sun, 11/12/2006 - 09:06
Submitted by dwcurtiss@virt… on Wed, 11/08/2006 - 12:39
Dash light question
Hi Martin,
I beleive the light comes on during a routine check of the lighting status; when all is deemed to be in working order the light goes out. At least it works this way in my XJ-S so am assuming it was carried forth to your '95, too.
2006 XJR
1990 XJ-S Conv
Submitted by y2kgolf@hotmail.com on Wed, 11/08/2006 - 12:03
Dash light question
Don,
That is correct. Along the same question; Once I turn on my headlights, the same light comes on for about 30 seconds or so, then goes off. Is that normal.
Martin
1995 XJS Convertible
Submitted by neffd@dteenergy.com on Sat, 11/04/2006 - 09:18
Dash light question
One or more of your brake lights is not working. Have someone step on the brake pedal while you check out the brake lights.
Don Neff
1991 XJ-S V12 Convertible 5-Speed
Don,
Thanks for reply. Right rear brake light was out
Herb
