I am having an electrical problem with my 2003 S-Type that apparently just developed.
Problem: Climate Control LCD panel has begun flashing at a regular interval when the Climate Control the system is on.
• Turning the system off sometimes results in simply a blank screen, as would be expected.
• Other times, the screen continues to flash but shows only remnants of the image seen when the system is on.
• Sometimes if the Climate Control LCD is still on at the moment the car is turned off, and one would expect the Climate Control LCD to turn off at that moment, the flashing image continues for a few seconds after the engine stops.
• This problem is inconsistent.
