- I purchased a front licence plate frame from welsh jaguar
for a '68 e-type
- it has a feature which allows the frame to hinge when the hood is open,
however it does not come with installation instructions and I have not
seen one installed before.
- I called welsh and they couldn't supply any instuctions or info
to help with installation.
- any info would be appreciated.
- thank you
Submitted by NC19-03320J on Thu, 07/07/2011 - 18:55
Submitted by SE98-32482CJ on Thu, 07/07/2011 - 10:31
front licence plate
Peter the bracket mounts to the lower lip of the bonnet mouth (should be holes there although they may have been filled at some time). There is also an elongated hole under the bonnet that a rod passes through to the front radiator and bonnet support frame--it should be clearly seen on the frame.
Peter, If you'll shoot an email to bobanddarl
comcast.net I'll send you a picture of the installed plate holder and rod that George described in the previous message.
Bob
