If you mean Zenith Stromberg carbs instead of SU my experience is the floats are prone to leaking which can result in fuel overflowing the float bowl. I have also had the float bowl needle stick and some times a tap with hammer on the carb body can un-stick it.
David Barnes
68 E-Type FHC
