Can anyone advise me please of the correct height adjustment for the headlamps on a 92 sovereign , it has the rectangle lamps and I know how to adjust them it's just the height I need please , thanks.
My Cat came back !
Submitted by pconnor@shaw.ca on Wed, 03/28/2007 - 20:37
Submitted by jeffrey_f_hubb… on Tue, 03/27/2007 - 15:14
HEADLIGHT ADJUSTMENT
This might help:
If you want to adjust your headlights yourself, you'll need 35 to 40 feet of flat space in front of a garage door or other flat surface.
Shine your low beams on a garage door from 2 to 3 feet away.
Outline the bright spots on the door with a soft pencil or tape.
Back car to about 25 feet from the garage door. The top of the low beams should shine no higher than the top of the marks on the door or lower than the center of the marked circle.
Make the necessary adjustments.
If you car has only two headlights, the high beams are automatically aimed when you aim the low beams. If your car has four headlights, aim the low beams first. They are the outer or upper two lights. Then adjust the high beams until the center of the high is at the top of the low beam.
found at: http://www.safetycenter.navy.mil/media/ashore/issues/spring01/howtodrive...
Good luck,
Jeff
1994 BRG XJ6
Thanks Jeff, it is very helpful , at present they are well low and I didn't want to guess and end blinding other motorist , now I have a good point of reference, thanks again .
Paul. My Cat came back !
