its a 1987 4 door with a v12, body tag says Vanden Plas v12 but all the sites that help you figure out the serial numbers dont work. I believe the car is originally from Ontario Canada. Under the hood stamped in metal is the serial # sajjbnlw4hf476695
on the door post is # sajbn1047hc476695
anybody able to figure this out, I would realy like the help.
Submitted by dougi@shaw.ca on Tue, 04/04/2006 - 20:05
Submitted by NC43-62049 on Tue, 04/04/2006 - 18:37
Re.: Help identifying my Jaguar
Edited on 2006-04-05 11:15:14
Check cars for sale on this website. I, like many others, regularly browse what is available.
Regards,
Dan Lokun
Toronto Canada
90 XJ-S
Submitted by kbobyk@yahoo.ca on Mon, 04/03/2006 - 20:36
thanks I was hoping it was a good model, I wish I could keep it but It was bought with the idea of re-selling. any ideas on value and a good place to advertise it?
Submitted by NC43-62049 on Mon, 04/03/2006 - 17:25
Edited on 2006-04-04 18:35:38
Sure is a Ser III VDP
Added bonus in Ontario, Canada, is that this particular year of car is now exempt from all emissions testing forever or until the rules change again.
Regards
Dan Lokun
Toronto Canada
90 XJ-S
Submitted by dougdwyer@adel… on Sun, 04/02/2006 - 03:12
Good for you. You've happened across a desirable model.
You've already identified it: A V12 VanDen Plas. It is a high spec model of the "Series III" saloon family.
Doug Dwyer
Longview Washington USA
1987 XJ6 Ser III
1988 XJS V12 Coupe
The value can be anywhere from a few thousand to thirty-five or forty thousand dollars, all depending on condition. If it is an average used example, it will need maintenance and safety attention that will easily run to a few thousand dollars. If it has rust, multiply by whatever you like. Buying these cars on speculation is rarely prudent, but good luck!
Doug Ingram
Victoria BC Canada
1969 E-Type OTS
1987 XJ6 VDP
2002 X-Type
