Can anyone say what should fill this hole?? Its the passenger side leg well, LHD, A/C 2+2. I dont remember it before it went to my mechanic!!
Submitted by mktr@charter.net on Fri, 07/29/2005 - 00:02
Submitted by mfrank@westnet.com on Wed, 07/27/2005 - 14:18
Hole in a 1973 2+2
I'm not sure where the starter is on a V12, but that's pretty close to where you would want to cut a hole to get to the starter on a six
Submitted by MikeEck@optonl… on Wed, 07/27/2005 - 14:18
Hole in a 1973 2+2
Did the mechanic work on the starter?
www.jaguarclock.com
'51 XK120 OTS
'62 3.8 MK2 MOD
'72 SIII E-Type 2+2
Submitted by pascal@jcna.com on Wed, 07/27/2005 - 14:03
Hole in a 1973 2+2
looks like an access hole for the transmission. Mine has a JT5 gearbox and i had the mechanic drill a hole to get to the filler. it's more or less in the same spot... but i can't imagine someone drilling THRU the carpet!!!
cna't be a hole for the A/C drains, they're inside the console...
Pascal Gademer
72 E-type 2+2
00 XKR Coupe
hi,dont want to offend but you dont have to cot a hole to get starter out on six cyl.
1962 fhc 1970 fhc
