I have a '72 series 1 that has a damaged ignition cylinder. I went to SNG barratt and they gave me a key set and a small cylinder. Anyone knows how to remove the one in my car if the key would not go in?
Any help is appreciated.
regards,
Jim
Submitted by jdevarie@usa.com on Thu, 11/24/2005 - 20:21
Submitted by bonnettoboot@e… on Mon, 11/21/2005 - 00:52
How to remove damage ignition key assembly?
Hello; It appears that you have been given the wrong lock parts. The part you describe is from an earlier car without a steering lock like the ser 1 E type etc. Your car has steering lock/key assy, they are hard to find and expensive,, search around for a good locksmith, Jaguar affectionado and etc.
William, thanks for your reply. It makes absolute sense. I will search for the correct part.
Regards,
Jim
Cogito ergo Zoom
It's better in a Jag.
