Gentlemen
I drive my Jag almost every day. On the way home this evening I turned on the headlights and the ignition light came on immediately. I turned the headlights out and the ignition light went out. Tried it several times with the same results. The in dash ammeter is showing a normal charge. I checked the belt adjustment and it is fine. Where do I look next?
Many Thanks / Jack
