Edward, the rear should be at the attaching points of the radius arm (big rubber puck) to the floor pan. The fronts can go under the lower a arm at the rear attaching to the sub frames. A 2x4 or rubber pad helps eliminate damage. Call me if you have any questions.
Cheers Tom
