i placed a post about this earlier. i was told to clean the microswitch. i did and the air and heat was working. then i closed the door came back and nothing. i dont have anything at all. i took it apart again and all i hear is a click at the junction where the wiring harness from the heater control unit,plugs into the main wiring harness. it sounds like a relay click. my dilema is before i buy a new control unit, what else can i check? do i just start replacing relays or what? thanks guys for the help, michael
Submitted by feduck@sympatico.ca on Sun, 10/02/2005 - 09:01
http://www.jag-lovers.org/ebooks/view.php?Vbook=xj40&Vsection=9.1.4
Follow that link (you have to register to view -it's free) and read the sections on AC heat repair.
B.F.
