just had a new panel sprayed in british racing green, finished job looks mat and does not have the same amount af gold flexs as threst of the car. Any ideas
Submitted by peddlarbob@gmail.com on Sat, 01/26/2013 - 08:36
Submitted by deltajhotel@aol.com on Thu, 01/24/2013 - 20:34
paint work on xf
Hi Sammy,
What is the paint code on your car, are you sure it references BRG, there are botanical greens, emerald fire greens. If it was resprayed using the same paint code color you need to investigate
That is the problem matching metallicÔÇÖs. The painter has to have both the paint and his air pressure just right to be able to manage a perfect match. On the only Jagauar I have ever had repainted. The painter ran about ten swabs before we even came close to having the perfect match.
