I have a 86 Jag XJS v12. ANd I need to remove the radiator. ANd as most of you may know the hood hinges are in the front. Which makes it kinda hard to get to. Do I have to remove the hood to get the radiator out? Advice greatly appreciated
Submitted by nathan.gallowa… on Sun, 06/25/2006 - 01:51
Submitted by dougdwyer@adel… on Sat, 06/24/2006 - 23:45
Radiator removal??
Fan, ac compressor, stuff like that. Use carboard or rubber mats. Better yet, remove the fan....
Doug Dwyer
Longview Washington USA
1987 XJ6 Ser III
1988 XJS V12 Coupe
Submitted by nathan.gallowa… on Sat, 06/24/2006 - 23:39
Radiator removal??
Cover which part of the engine? The "V"? Or where the water pump and stuff is? It looks like an awful tight fit. Gonna give it a whirl tomorrow. Thanks?
Submitted by dougdwyer@adel… on Sat, 06/24/2006 - 23:33
Radiator removal??
No, it can be lifted-and-tilted out. Drape some heavy material over the front of the engine so you don't gouge the *&^$ out of it and you'll be wise to enlist a second set of hands
Doug Dwyer
1987 XJ6 Ser III
1988 XJS V12 Coupe
Edited on 2006-06-25 1:52:27
sweet thanks man.
