Stephan, because Im stuck in 30 inches of snow, Im on a roll annoying people in a loving way today on the forum....TEE HEE....
If your 3 way is not hooked up? lets start ALLL OVER AGAIN
1 STOCK ALTERNATOR, NOT 1 WIRE?
2. If stock, is the regulator hooked up.
3. Is your fuel tank low? , yes check it and see if YOU switched the wires if the gas is swishing low, the light would come on and off.
4. Alt relay is in the back of the drivers fender, make sure all the wires are connected.
If the alt checks out and charging and all else is okay, Change the relay.
You know this only makes half sense , like Jacks case because the lite is coming on but not attached to anything?
As always good luck
GTJOEY1314
