Edited on 2010-09-06 12:13:51
Looking at a 2001 4.0 XK8, 49K and noticed at idle there is slight tappet noise. Is this normal? Engine has plenty power and runs smooth. My other Jags engine is a 4.2 and is quite as a mouse.
Steven Petry, if you see this, when you have time, would you contact me off forum. I would like to talk to you about this car. 850-625-9435, or vineyardman68
comcast.net
Regards
Garfield
05/XJ8L
Submitted by daniel_satur@h… on Sat, 10/23/2010 - 02:05
Submitted by smose2400@sbcg… on Mon, 09/06/2010 - 18:07
Re.: Tappet Noise's
I agree with William. If the work on updating the timing chain tensioners has not been completed, my best guess is... that is the problem. Before my 1997 XK8 had this work done it sounded like a tappet type noise. The upper tensioner is the most crucial of the two as it can "take out" the motor.
Scott
2001 Jaguar S Type 4.0
1997 Jaguar XK8 Convertible
Submitted by bonnettoboot@e… on Mon, 09/06/2010 - 17:15
Re.: Tappet Noise's
Make sure it isn't a chain/tensioner noise, ie, has it been modified with the updated tensioners!
Is the problem on bank1 , or bank2?
