Hello,
I have a 1990 XJS V12 5.3L that idles a little rough at 700 rpm. If i press the gas pedal to about 900 rpm it smooths out a bit.
What kinds of things should I look at to smooth the idle. This is with 89 and/or 93 octane gas.
Thank you,
Mike Moore
1990 XJS Coupe
Tampa, Florida, USA
        Submitted by zaphod_69@hotm… on Wed, 05/09/2007 - 18:07
Submitted by dwcurtiss@virt… on Tue, 01/02/2007 - 19:39
Rough Idle, 1990 XJS V12 5.3L
Hi Mike,
Just a few (gazillon) things might be causing the rough idle :o)
1. Spark plub wires might be broken-down(leaking)if they are older.
2. O2 sensors (two of 'em) might be suspect if they are older.
3. Spark plug gap - if too wide it will put a load on the distributor cap. If bad enough you could get a melt-down of the cap. (Good luck getting to plug #1; you'll have to loosen the AC compressor and move it out of the way).
4. Inspect the injection wiring harness for cracks; the wiring is subject to heat break-down since it is unfortunately located in the valley.
While you are at it - check the fuel injection lines for leaks - an ignition source + fuel leakage = engine fire.
Dwight Curtiss
2006 XJR
1990 XJ-S Conv
Hi Mike
The HE engine never idled quite as smoothly as it's predecessor but it's normally not horribly bad ...the odd puff from one bank or other...If you are doing a great deal of short runs & gentle driving you could try a bottle of Injector cleaner & a good long run ..Hold it in selected Second & keep the revs around 3500 ..light load on the engine ..every now & then stomp on it for a second or 2 ( Get the full Load switch activated & the kickdown too ) sometimes it's just dirty injectors that aren't closing properly that mess up the idle.
