Does anyone have a suggestion(s) regarding a method to assist in the replacement of the rubber seals on the side windows of my '63 Coupe? Thanks!
Submitted by jklekas@aol.com on Sat, 08/27/2011 - 15:35
Submitted by tvtom@sbcglobal.net on Sat, 08/27/2011 - 12:07
Submitted by bonnettoboot@e… on Fri, 08/26/2011 - 23:27
Re.: Rubber seal replacement.
Silicon fluid (as used on brake systems) is an excellent lubricant.
Submitted by tvtom@sbcglobal.net on Fri, 08/26/2011 - 22:52
Thanks, Jerry.
I was wondering whether someone had a suggestion for a non-destructive lubricant to be used in installing the seals in the grooves surrounding the door windows on an E-Type Coupe.
I did it once long ago and, as I recall, it was not easy.
Tom
Submitted by jerry@moutons.org on Thu, 08/25/2011 - 11:20
Edited on 2011-08-25 11:21:53
Tom, You mean the Non-Draught Ventilators? Not that big a deal.
First, remove the windows -- 6 screws I believe
Then you should be able to just pull the rubber out of the metal tracks fastened to the car body. To replace you just push the new ones back into the tracks. New tracks are available if the old ones are rusty. Be sure to caulk behind the tracks before you install the rubber because water can go behind them even if the rubber is effective.
Also, pay attention to the ends of the rubber seals, that they seal well with the body or adjacent rubber. That's a source of wind and water leaks.
Or did you mean something else?
Careful about using any type of brake fluid around paint.
