Does anyone know, if any of the wires going to the 3AW or the 4RT relays, are "Switched battery positive 'ignition switch' supply connection". With an updated 3 wire alternator, thanks to recent suggestions and member advice, the 3AW relay and the external regulator are now out of that loop. The battery post needs no explanation, I found the light wire that used to go through the 3AW, now where does one connect the remaining Switched battery positive wire. Do any of the already existing, now unused connections, fit the description - or do i have to go someplace else, and if so, what's the easiest to reach.
Thank you, all, for advice on this and the alternator.
