i'm not sure what modification is needed to the distributor when i install triple weber dcoe45' s in place of dual strombergs.
my existing distributor does not have a vacuum connection.  is mechanical advance enough, and if so do i need to recurve the distributor??
Submitted by bonnettoboot@e… on Thu, 11/02/2006 - 23:56
Submitted by mdipple@tampab… on Thu, 11/02/2006 - 21:58
weber installation/ distributor question
Good question, Let me know when you have a answer, Thanks,Mick Yea baby, Behave.
You should definitely get a distributor with Vac adv. You can buy a used unit from an earlier car, almost any jag pre 68 will work, if so you need to create a throttle body connection port if there isn't one on the webers. OR perhaps you should just convert to an new electronic unit available from the many jag parts sources. Jaguar affectionado and etc.
