Where can I find a detailed guide for harness routing for my 1967 S1 OTS. I have the correct wiring diagram. Following a bare metal restoration, most of the main harness wiring is installed, including power, ignition and instruments I still need to wire the lighting in the boot and bonnet. The car is running great but, because the old gas tank sprung a pinhole leak, I'm fitting a new replacement; only want to do this job once, so I want to get it right.
John
