I bought an overdrive transmission on e-bay that works fine but I have a problem with the speedometer drive.
The fitting on the transmission has a 1/2" diameter connector, but the right andle drive on the speedometer cable is for a 3/4" diameter connector. Is there another right angle drive available, or is there an adapter? If so what is the part #, and where could I get one? Any help would be apreciated.
Submitted by SE98-32482CJ on Sat, 02/27/2010 - 16:03
Yes and you just need to buy the correct one--make sure you get the correct ratio.
