Need some suggestions on cold starting. Car runs beautifully once started but always a problem from cold. I have checked all of the obvious issues, good spark, no vacuum leaks, etc Have dissembled starting carb several times and the solenoid is working well have adjusted it by the book, and never seems exactly right, and always needs a lot of tries before it fires, and then only with lots of throttle juggling. Need a new approach??
