I am re-upholstering the door panels of my XK150S roadster.  Could somebody e-mail me a couple of detail photos of the interior door panels.
Submitted by SE98-32482CJ on Fri, 04/22/2011 - 15:37
Submitted by ddurrant@charter.net on Fri, 04/22/2011 - 13:14
XK150 DOOR PANELS
George,
I presently do not belong to any club.   I got the door kit from Bill Bassett in Rhode Island.
Chassis no. iS T831978 DN
Submitted by SE98-32482CJ on Wed, 04/20/2011 - 13:04
XK150 DOOR PANELS
David are you a JCNA member--if so why not post your club under your name--it would certainly motivate me to dig up pictures. You also need to include the chassis number as the door changed during 1959. By the way are you doing the car in the correct material--if so where did you find it?
David you have a "pocket" that goes in first. Then you have a upper cover then two side covers-front and rear and lastly the door panel. I have not checked but if your car has the ash trays in the door you will need to shim them with wood or your windows will not function correctly--lastly the hardware and arm rests go on. All is clips and rivets except the bottom edge which is finished in screws and cups!
