I'm installing a bonnet and alternator harness and need to know how these are routed through the two holes provided behind the regulator mount.
Do they both go through the top hole, or do you use the top and bottom hole? Anyone have photos?
Thanks to anyone who can provide answers.
Ed
OTS XKE 1967
Submitted by mcload@ev1.net on Sun, 03/09/2003 - 21:02
Ed: I will try to send you a photo in the next couple of days if you haven't already found the fix. However, the larger main engine harness routes through the larger lower hole, and there is a large clip right there at the exit of the hole. The alternator harness and 4TR connector routes through the upper smaller hole; there is no clamp for this harness.
Hope this helps.
Regards,
Patrick McLoad
#1E1445
